power2max: pregunta aquí lo que quieras
Tema en 'Material' iniciado por andr3s_diaz, 4 Ago 2014.
  1. nisarga
    nisarga Miembro
    7 Sep 2009
    Midiendo en la araña no se puede separar la contribución de cada pierna. Para ello hace falta medir en los pedales (en los dos) o en las bielas (en las dos).
    En caso de que te interese leer algo más sobre el tema del "power balance", puedes encontrar la explicación con figuras y todo en el blog de DCRainmaker.
    Te pego dos párrafos al respecto de https://www.dcrainmaker.com/2016/09/power-meters-buyers-guide2016-edition.html
    "Estimated Left/Right Power: This became all the rage just prior to true left/right units coming out, starting with the SRAM/Quarq RED unit offering left/right power. That platform works by essentially splitting your crank in half and assuming that any power recorded while pulling up is actually coming from the left side, whereas pushing down is from the right side. Thus, an estimation. It’s good, but not perfect. Note that even with true left/right power (below), there’s actually very little in the scientific community around what to do with the data. While you may think that perfect balance would be ideal – that hasn’t been established. And some that have looked into it have found that trying to achieve balance actually lowers your overall output. The only thing folks agree on is that measuring left/right power can be useful for those recovering from single-leg injury. The PowerTap C1, Power2Max units, and all SRAM/Quarq models currently on the market use this method.
    Actual or True Left/Right Power: This is limited to units that can measure your power in more than one location. Thus why we see it on pedals, as well as the more expensive crank-arm or pedal based power meters. You can’t measure it directly at the spider, instead you have to measure it upstream of that such as the cranks (ROTOR dual system, Infocrank’s dual system, Pioneer’s dual system, WatTeam, Shimano’s dual system, 4iiii’s dual system), pedals (Garmin, bePRO, Polar/Look, Look alone, Xpedo), or cleats (Brim Brothers).
  2. saltamatorrales
    saltamatorrales Miembro
    3 Dic 2014
    Hola tengo una duda respecto al montaje de unos platos Rotor en mi P2m, tengo mismas bielas,platos y p2m en las 2 bicis , después de montarlos me he fijado que están montados diferentes los 2 platos pequeños , es decir que uno está bien y otro mal. El logotipo del plato pequeño tiene que ir hacia el lado del plato o hacia el otro? Adjunto fotos , un saludo y gracias de antemano ( he buscado vídeos de montaje pero no me ha despejado dudas) IMG_20161216_162619894.jpg IMG_20161216_162619894.jpg IMG_20161216_181248255.jpg IMG_20161216_181248255.jpg
  3. Kos_q
    Kos_q Efectivamente y no
    26 Ago 2005
    Por el Somontano de Barbastro
    El logotipo siempre para afuera, en las fotos esta del reves.
  4. saltamatorrales
    3 Dic 2014
    Entonces las primeras 2 fotos es donde esta bien colocado y las 2 siguientes mal no? lo digo por que hay una foto de cada. Gracias por ctt
  5. josy1974
    josy1974 Miembro Reconocido
    25 Jul 2008
    fijate en el plato,en los agujeros por los dos lados no son iguales,tienen un pequeño rebaje para el apoyo del tornillo.el rebaje siempre hacia el lado del cuadro.
  6. saltamatorrales
    3 Dic 2014
    Gracias, tendre que desmontarlos para comprobarlo pero creo que son los de las 2 ultimas fotos.
    y otra dudilla, si estan al reves ocurre algo en el funcionamiento ? aparte de algo de ruido?
  7. josy1974
    25 Jul 2008
    claro,si estan al reves ocurre que no esta bien la medida entre ellos y la cadena no engranara bien y hara ruido.
    ponerlos bien es fundamental.
    si los as montado tu bueno es perdonable pero como te los hayan montado es un fayo imperdonable.
  8. saltamatorrales
    3 Dic 2014
    Fallo mio, desmonte todo a finales de noviembre para limpiar,engrasar,... y no lo monte hasta hace 3 dias, y ya ni me acordaba ,de ahi mis dudas. Muchas gracias compañero!
  9. sermanuel
    sermanuel Miembro Reconocido
    18 Ago 2011
    estan mal en las dos primras compañero
  10. nisarga
    nisarga Miembro
    7 Sep 2009
    Buen día, soy un completo ignorante en esto de bielas, ejes y cazoletas, y tengo la siguiente duda:
    Tengo una bici con cuadro BSA y en mis cazoletas pone:
    BC1.37x24
    Creo que si quiero instalar un power2max con bielas Rotor de 30mm necesito cambiar las cazoletas y poner esto.
    http://www.kingbarcelona.com/es/cazoletas-rotor-bsa30-p-9549.html
    Mi duda surge en el caso de un power2max con bielas Rotor de 24mm. ¿Podría usar las cazoletas que tengo o necesitaría cambiarlas y poner esto?
    http://www.kingbarcelona.com/es/caz...edium=items&utm_campaign=itemnotavailablepage
    Creo que no necesitaría cambiarlas pero quiero estar completamente seguro.
  11. josy1974
    25 Jul 2008
    si quieres poner rotor,no valen las cazoletas que tengas en tus bielas a no ser que tengas bielas rotor.
    rotor usa sus propias cazoletas.
  12. saltamatorrales
    3 Dic 2014
    No fastidies! Y eso porque? Yo que pensaba que eran las buenas . lo mejor será que desmonte las 2 y mire bien. Gracias ;)
  13. scalator7
    scalator7 Miembro Reconocido
    23 Oct 2015
    Si el eje es de 24mm te valen las cazoletas de ahora para unas bielas rotor 3d24....
    Si le quieres meter 30mm tienes que cambiar
    Resumiendo:
    Eje 24mm te valen tooodos
    Eje 30 tienes que cambiar
  14. saltamatorrales
    3 Dic 2014
    Eso no era para mí no Scalator 7?
  15. scalator7
    23 Oct 2015
    Ostras no!!! Jiji
    Era para @nisarga
  16. nisarga
    nisarga Miembro
    7 Sep 2009
    Creo que la respuesta era para mi.
    Muchas gracias a josy1974 y scalator7.
  17. meanmachine
    meanmachine Miembro activo
    15 Feb 2006
    Flandes
    Hola
    Queremos montar un power2max Type-S ( kit de bielas ROTOR 3d+ ) en una BH Ultralight que lleva pedalier BB386,
    http://www.power2max.de/europe/es/P...ower2max-type-s-rotor-3d-plus-2014-carretera/
    La web de power2max dice que para ver si es compatible hay que medir el exterior del orificio del cuadro (si es menor de 57mm) serán compatibles
    http://www.power2max.de/europe/es/support/frame-compatibility/
    Compatibilidad con power2max y modelos recomendados
    Sólo necesitas comprobar la compatibilidad en cuadros BB86 y BB386EVO, todos los demás tipos de cuadros son siempre compatibles con power2max. Para comprobar la compatibilidad, por favor mide el diámetro exterior del orificio del eje pedalier. No debería exceder de 53mm para montar power2max Classic y de 57mm para montar power2max Type S para estar seguros de la compatibilidad con power2max
    Tenéis alguno este kit de bielas ROTOR 3D+ y sensor type-S instalado en un cuadro BH ultralight con este pedalier BB386 ??'
  18. scalator7
    23 Oct 2015
    A alguien le ha salido ya el NG?
  19. M1gu3l
    M1gu3l Miembro Reconocido
    8 Mar 2009
    Pedido pendiente desde el miercoles 14.
    Si tarda 4 semanas supongo que hasta fin de año no lo enviaran, espero que me equivoque
  20. josy1974
    25 Jul 2008
    a mi todabia no,como bien dicen hasta dentro de 4 semanas.
    de echo a mi tambien me cobraron el cable USB lo he reclamado y estoy a ver si me devuelven los 20€.
