Garmin Edge 820
  1. tyrun
    tyrun Miembro Reconocido
    18 Oct 2015
    Bueno, pues parece que lo tenemos aquí:
    Diferencias 820/520plus/1030
    Edge 820/1030 has a touch screen, Edge 520/520 Plus doesn’t
    – Edge 1030 connects to Bluetooth Smart sensors, Edge 520/520 Plus/820 lack that hardware
    – Edge 820/1030 has point of interest database (for things like restaurants, convenience stores, hotels, etc…)
    – Edge 820 doesn’t have Trendline popularity routing, Edge 1030 does
    – Edge 820/1030 can route to a specific street address on the unit itself (I.e. 123 Maple Drive, New York, NY), the Edge 520/520 Plus have to have pre-defined routes (Note: The Edge 520/520 Plus can, however, do turn by turn navigation route to previously saved points)
    – Edge 820/1030 have WiFi, Edge 520 series doesn’t
    – Edge 1030 has latest FirstBeat driven recovery and training load metrics, Edge 520/520 Plus only has a limited subset for VO2Max and Recovery Advisor
    – Edge 1030 is compatible with secondary battery pack, Edge 520 Plus/820 are not
    https://www.dcrainmaker.com/2018/04/hands-on-garmin-edge-520-plus-with-mapping.html
    Novedades principales respecto al Edge 810:
    -GLONASS
    -Notificaciones móviles
    -Wifi
    -16 gb internos (no micro sd)
    -Métricas avanzadas (Ftp, VO2, Umbral de lactato,...)
    -Grouptrack
    -ANT+FE-C
    -Connect IQ
    -Transferencia
    -Alerta de accidente
    -Indicaciones de voz (via smartphone)
    -Sensor iluminacion
    PVP Oficial (Garmin.com)
    Edge 820--->400€
    Edge 820 pack--->500€
    Edge Explore 820--->350€
    La versión explore es igual a la "normal" pero sin:
    -Soporte para medidor de potencia
    -Sensor de iluminación
    -Entrenamientos estructurados
    -Wifi
    -Métricas avanzadas
    https://www.correrunamaraton.com/garmin-edge-820-garmin-renueva-la-gama-800/
    https://buy.garmin.com/es-ES/ES/prod543199.html
    https://the5krunner.com/2016/07/13/comparison-garmin-edge-820-vs-garmin-edge-810-vs-garmin-edge-520/
    https://the5krunner.com/2016/07/13/opinion-garmin-edge-820/
    http://www.dcrainmaker.com/2016/07/garmin-edge-820.html
    Ostras, trae 4 mapas ¿que es cada uno?
    ¿Cómo puedo crear una copia de seguridad de mis valores personales y perfiles en mi Edge?¿Cómo puedo hacer un hard reset?
    El enlace de Garmin ha volado. Guia para hacer el backup: https://www.correrunamaraton.com/backup-garmin/
    ¿Problemas con la pantalla tactil?
    Funciona en la 5.20 --> https://forums.garmin.com/showthread.php?371029-Edge-820-touch-screen-issues-Solution
    (006B255000.zip esta subido como adjunto a este post, descargar al final del mismo.)
    ¿Se pueden modificar los km totales en el dispositivo? Pues sí:
    Volver a un firmware anterior:
    Para volver a una version anterior bajar el archivo que corresponda, copiarlo en la carpeta garmin y renombralo a gupdate.gcd http://gawisp.com/perry/edge/
    desnchufarlo y actualizar
    cada vez que se enchufe al ordenador hay que borrar el archivo gupdate.gcd
    (Basado en un aporte original de @mataix :D, gracias)
    Firmware actual: 11.2
    Historial de actualizaciones:
    http://www8.garmin.com/support/download_details.jsp?id=10387
    ATENCION:
    Un gran numero de usuarios estan teniendo problemas con un halo alrededor de la pantalla. El halo solo es visible con la retroiluminacion apagada. Garmin esta al corriente de ello y como es logico se esta haciendo cargo en garantia. Podeis tramitarla en la tienda donde lo comprasteis o bien directamente a traves de Garmin. https://support.garmin.com/faqSearch/es-ES/faq/content/UwHTK3Xuko5eNMK2b6nCn5
    Tambien hay un hilo en los foros de Garmin hablndo de ello:
    https://forums.garmin.com/showthread.php?377819-Screen-halo
    • Me Gusta Me Gusta x 13
    • Útil Útil x 5
    Última edición: 24 Jun 2019
  2. JOSEPV
    JOSEPV Miembro Reconocido
    20 Nov 2008
    Vila-real (Castellon)
    Tiene muy buena pinta, haber los precios finales en tienda.
    Enviado desde mi GT-I8200 mediante Tapatalk
  3. Alemalaga
    Alemalaga Miembro activo
    2 Nov 2014
    Parece que no acepta tarjetas sd no?
  4. tyrun
    18 Oct 2015
  5. Yakima
    Yakima Miembro
    27 Dic 2015
  6. Adri96
    Adri96 Miembro Reconocido
    30 May 2012
    Muy buena pinta, siguiendo el diseño que iniciaron el año pasado con el 520
  7. tyrun
    18 Oct 2015
    De momento ya lo tienen en algún sitio para reserva a 390€ la versión normal y 330€ la versión Explore con entrega estimada a mediados de Agosto.
    La versión Explore no lleva wifi, ni sensor de luz, ni es compatible con medidores de potencia, ni acepta entrenamientos estructurados ni "metricas avanzadas". Vamos como el 1000 y el 1000 explore, creo.
  8. gullate
    gullate Miembro Reconocido
    5 Jun 2014
    Parece que mi 1000 ya tiene los días contados
  9. fossy
    fossy Miembro Reconocido
    15 Ago 2013
    Regalamelo
    La verdad es que por el precio que sale... Seguro que hay algún 1000 por ahí de oferta que cuesta lo mismo o incluso menos...
    Enviado desde mi Lenovo A7600-F mediante Tapatalk
  10. nunokas
    nunokas Miembro Reconocido
    12 Ene 2016
    Mi 810 tiene los dias contados :D
    A ver su estabilidad en lo software...
  11. Yakima
    Yakima Miembro
    27 Dic 2015
    Si es como el 520, debería ir bastante rodado desde el principio...
  12. joker
    joker whatthefuck!
    Según DCRainmaker son 16GB de memoria interna no 8GB.....
  13. tyrun
    18 Oct 2015
    Pues si, lo ha corregido dice que el suyo venia con 6,1 gb libres, pero la total son 16. Lo que yo no entiendo como queda tan poca memoria para el usuario. Bueno, mientras quepa el Topohispania... :D
  14. mataix
    mataix Miembro Reconocido
    10 Oct 2005
    si tiene la conexion con el red etap cae uno fijo
  15. Alemalaga
    2 Nov 2014
    Este cacharro para el monte cómo irá?
  16. nunokas
    12 Ene 2016
    Con glonass ira mejor que el 810.
  17. carloslen91
    carloslen91 Miembro activo
    11 Dic 2011
    Albacete
    Para mi el fallo ha sido no ponerle para insertar SD :(
  18. djcasiano
    djcasiano Miembro activo
    1 Mar 2012
    Zaragoza
    Muy buena pinta tiene
    Entonces decís que hasta mediados de agosto no sirven unidades?
  19. mataix
    10 Oct 2005
    Aquí es precisamente lo que hay de nuevo en el Edge 820 (y si se detecta en otras unidades de Garmin):
    - Se añaden en el Grupo de Seguimiento (acecho sus amigos)
    - Contiene completa / detallada cartografía / enrutamiento (como Edge 1000)
    - Contiene 16 GB de almacenamiento interno (sin ranura para tarjetas micro-SD, aunque)
    - Añade en mensajes de audio basadas en teléfono (como llevar encima Garmin )
    - añade en Incidente / Detección de emergencia / Notificaciones (como Edge Explora 1000)
    - Se añaden en nueva puntuación estrés (visto en vestibles)
    - tiene WiFi (en Edge 1000, pero no Edge 520)
    - Tiene una pantalla táctil (como el Edge 1000)
    - Tiene un lugar fresco nueva 'batería ahorre el modo' (nunca visto antes)
    Así que ¿hay cosas que no se encuentran en el garmin 820 que están en el garmin 1000? Sólo algunos:
    - No tiene modo de paisaje (por pantalla giratoria)
    - No tiene la ranura para tarjetas micro-SD (durante más de 16 GB de mapas)
    - Tiene una pantalla más pequeña que la Edge 1000
    Y eso es.
    En cuanto a la Edge Explora 820, aquí es cómo es diferente que el borde de la base 820:
    - No hay WiFi
    - No Sensor de luz ambiental
    - No ANT + Medidor de energía o respaldar el paso
    - No Soporte Formación estructurada (es decir, los entrenamientos estructurados)
    - No hay métricas avanzadas como indicador de rendimiento, FTP, etc ...
  20. el_dubau
    el_dubau Miembro Reconocido
    1 Ago 2006
    Valladolid
    Interesante, esperemos otro PrimeDay de Amazon para que lo tengan :)
