El post del Garmin Fenix 3
  1. newal
    newal Miembro activo
    24 May 2009
    Es un fallo de Garmin Connect. No tiene nada que ver con el Fénix ni con la versión de software
  2. junaca74
    junaca74 Miembro activo
    10 Mar 2015
    Bapalomo con la nueva actu la 6,80 han modificado ese problema
  3. bapalomo
    bapalomo Miembro Reconocido
    12 Dic 2010
    Genial gracias
  4. Zhuravlik
    Zhuravlik Miembro
    8 Oct 2008
    Donosti
    Me acaba de saltar la actualizacion 6.80 a ver que trae...
    Change History
    Changes made from version 6.50 to 6.80:
    • Added support for Connect IQ SDK 1.2.2.
    • Added Intensity Minutes widget (Settings > Widgets). Note: requires a connection to a Heart Rate Strap to accrue Vigorous minutes.
    • Restored support for the (optional) manual entry of Sleep mode (Settings > Activity Tracking).
    • Added support for 'Auto Do Not Disturb'. (Power Menu > Do Not Disturb > Sleep Time) Sleep and wake up times can be setup through Garmin Connect Mobile.
    • Added support for Speed/Pace and Heart Rate audio prompts. (Requires Garmin Connect Mobile App app version 3.2.1, select More > Settings > Device > Audio Prompts to configure)
    • Improved list of app activities shown during navigation and interval training.
    • Fixed an issue where users were seeing auto lap information during swim activities.
    • Fixed potential issue with battery drain when using Analog watch faces. (Requires display update 3.20)
    • Fixed a potential issue with display of day/month on the watch face. (Requires display update 3.20)
    • Fixed a potential issue with the back light coming on for Smart Notifications, after placing the watch in 'Do Not Disturb' mode.
    • Fixed a potential issue with the vibration setting getting affected after a software update.
  5. germanete
    germanete Miembro Reconocido
    27 Ene 2012
    A mi es al revés, con la 6.50 la batería me dura mas que nunca. De hecho me pensaré si actualizar a las nuevas versiones hasta que las mejoras me sean sustanciales por lo bien que me va ahora.
  6. germanete
    27 Ene 2012
    Por si alguien prefiere leer comentarios de la gente que va actualizando este es el hilo oficial en los foros de Garmin: https://forums.garmin.com/showthread.php?343139-Fenix-3-Firmware-Version-6-80-Release
    Pensar normalmente solemos escribir cuando no nos funciona bien y no cuando lo hace ;)
  7. junaca74
    10 Mar 2015
    Se ha añadido soporte para Connect IQ SDK 1.2.2.
    Intensidad de widgets añadido Minutos (Ajustes> Widgets). Nota: requiere una conexión a una banda de frecuencia cardíaca para acumular minutos vigorosa.
    restaurada apoyo para el (opcional) la introducción manual del modo Dormir (Ajustes> seguimiento de actividad).
    apoyo a 'Auto de No Molestar' añadido. (Power Menu> No molestar> Sleep Time) del sueño y despertar veces puede ser configurado a través de Garmin Connect Mobile.
    Se ha añadido soporte para la velocidad / ritmo y de la frecuencia cardíaca mensajes de audio. (Requiere Garmin Connect Mobile App versión 3.2.1, seleccione Más> Ajustes> Dispositivo> Audio pide que configure)
    Mejora de la lista de actividades de las aplicaciones que se muestran durante la navegación y el entrenamiento a intervalos.
    Se ha solucionado un problema por el que los usuarios estaban viendo información de la vuelta automática durante las actividades de natación.
    Corregido problema potencial con el consumo de la batería utilizando las caras del reloj analógico. (Requiere actualización de la pantalla 3.20)
    Se ha corregido un problema potencial con visualización de día / mes en la esfera del reloj. (Requiere actualización de la pantalla 3.20)
    Se ha corregido un problema potencial con la luz de fondo que viene en para Smart Notificaciones, después de colocar el reloj en el modo "No molestar '.
    Se ha corregido un problema potencial con el tipo de vibración conseguir
  8. Binomio Karmesi
    Binomio Karmesi Miembro Reconocido
    24 Dic 2008
    Alguien ha averiguado para qué sirve la app incluida en el fenix llamada 'Project Wpt'?
  9. rdm01
    rdm01 Miembro activo
    9 Sep 2015
    Bratislava
    Creo que es para medir aéreas como hacia el fenix 2, pero no lo he probado.
    Edito: Sirve para marcar un POI de manera remota. Esto es, tú estás en un ubicación determinada, y quieres mqrcar un POI a 200 metros de tu ubicación em dirección Este, pues con esa aplicación puedes hacerlo indicando la dirección (antes puedes ver la dirección con el widget de la brújula) y la distancia desde donde te encuentras (a ojímetro, jeje)
    Última edición: 10 Feb 2016
  10. javi31_gt
    javi31_gt Miembro activo
    6 Sep 2012
  11. javi31_gt
    6 Sep 2012
    muy bien, pero siguen sin poder hacerse entrenos ni series de natación planificadas en garmin connect...
  12. Binomio Karmesi
    24 Dic 2008
    Genial! Gracias!
    EDITO
    Para activar el modo sueño: Settings - Activity tracking - Go to Sleep - Yes/No.
    Muy fácil de acceder, no? Antes, desde el widget de actividad se accedia, pero era muy engorroso. Ahora está mejor.
    Nótese la ironía :(
  13. Chusmamorate
    Chusmamorate Novato
    15 Dic 2015
    Buenas, he conectado el reloj al PC para cargar la batería y cuando se ha cargado le he desconectado correctamente en modo seguro y se me ha quedado colgado con el logotipo de Garmin, por más que lo apago y lo enciendo sigue el logotipo y si lo conecto al PC no me lo reconoce...¿qué puedo hacer?
  14. rdm01
    9 Sep 2015
    Bratislava
    Pues me temo.que intentar un hard reset y si no al SAT :-(
    Aquí http://www.deporteporvida.com/2015/12/solucion-situaciones-comunes-garmin.html puedes ver cómo se hace. Suerte!!
  15. abade_abad
    abade_abad Miembro Reconocido
    27 Ago 2008
    Mérida
    prueba a hacer un hard reset.
  16. abade_abad
    27 Ago 2008
    Mérida
    bastante gente se está quejando de la aparición de actividades fantasma en Garmin Connect con la nueva versión 6.80 del firmware.
    Aunque hay algunas novedades que me interesan, creo que esta vez voy a esperar un poco, estoy muy contento de cómo funciona el reloj ahora.
  17. junaca74
    10 Mar 2015
    Mantén el botón de star 1 minuto apretado más o menos luego sueltalo si no se t reinicia ,prueba con el HARD REST
  18. germanete
    27 Ene 2012
    El caso es que estuve siguiendo el hilo de las betas anteriores a esta versión y parecía que habían solucionado el tema de las actividades fantasma que salían en las primeras beta. Me parece que los responsables de desarrollo de Garmin deberían tomarse unos días de vacaciones y volver con la cabeza mas despejada, ya que cometen fallos evidentes de forma cíclica.
    Yo he dicho que me esperaré a actualizar, pero ya verás como pronto me pica el gusanillo y lo hago, no hay nada como el riesgo :p
  19. newal
    24 May 2009
    A mi me acaba de pasar... De repente me salta Strava con un "Tu carrera está lista". 12 minutos y 0m recorridos.
    Y ahí estaba en el reloj...
  20. rdm01
    9 Sep 2015
    Bratislava
    Qué desastre!! Me pregunto para qué vale entonces el canal beta si luego estas cosas no se detectan y corrigen antes de sacar la estable :-(
