El post del Garmin Fenix 3
  1. THINK BIKE Zorro
    THINK BIKE Zorro Miembro
    5 Ago 2009
    Garmin sube a Connect, pero puedes configurar Strava para que se sincronice con Connect automáticamente. Tapiriik es menos automático.
  2. Binomio Karmesi
    Binomio Karmesi Miembro Reconocido
    24 Dic 2008
    Para bajar de un firmware a otro:
    Firmware downgrade
    Thx to findings of other forum members described in this POST
    1. Download and install WEBUPDATER
    2. Download firmware from this LINK
    3. Create a shortcut to WEBUPDATER on your desktop
    4. Connect your watch and wait until Garmin Express finishes sync, BACKUP your data if you need it
    5. Drag the downloaded *.RGN file to the shortcut, it will start webupdater.. click next until it starts updating
    6. Disconnect your watch, it should ask if you want to update to the new (old) firmware.. it resets user data like in Hard Reset - method 1 described above
    Tested it 4.4->3.8 on a PC and it worked
    NOTE: There was no need to rename the downloaded Fenix3_380.rgn file to gupdate.rgn or cut the 30 bytes as was suggested in other posts. I don't know if it works this way on MAC though
    NOTE: Since revoking of the BETA testing procedure the watch seems to update just by putting the update file renamed to gupdate.rgn in the /GARMIN directory.. at least it works with files posted by GARMIN
    Fuente: https://forums.garmin.com/showthread.php?227684-Hard-reset-Service-menu-Data-Backup
    Pasos para actualizar:
    1. Attach your Fenix 3 to your computer via the charge clip
    2. Access the \Garmin folder once your device enters mass storage mode
    3. Unzip the 4.62 file and place 4.62_gupdate.rgn in the \Garmin folder
    4. Rename the [4.62_gupdate.rgn] file to [gupdate.rgn]
    5. Remove your Fenix 3 from the charge clip
    6. Proceed with the update process once prompted (if not prompted, try rebooting your watch or clicking the Down button)
    7. After the update, reattach your Fenix 3 to your computer via the charge clip
    8. Let Garmin Express finish syncing
    9. Go to Garmin Connect web page, go to calendar, click the arrow at the top right side of the page to send workouts to your device
    10. Wait for Garmin Express to finish syncing
    11. Remove your Fenix 3 from the charge clip
    12. Wait for the watch to finish installing the calendar items
    13. Skip 13 because it's unlucky
    14. Check your Training Calendar and ensure the proper workouts are listed
    Fuente: https://forums.garmin.com/showthread.php?321326-Fenix-3-4-62Beta&p=719536#post719536
  3. Binomio Karmesi
    24 Dic 2008
    Sí, así lo tengo yo configurado. Lo que ocurre es que quería unificar mis datos y entrenamentos en Garmin Connect, VeloHero y TrainingStageBuch. Y mirando, mirando, me topé con Tapiriik (que me sirvió para Connect y VeloHero, pero no para TrainingStageBuch :( ). Por eso lo he comentado. Si pagas una cantidad simbólica, la autosincronización (sin tener que intervenir uno accediendo a la página de Tapiriik) se hace de forma automática.
    De todos modos, lo más rápido es vincular todo lo que se pueda a Garmin Connect para que, aprovechando la conexión BT y WiFi del Fenix3 y subida instantánea de los ejercicios a Garmin Connect, quien se encargue de sincronizar las restantes cuentas en las distintas plataformas sea el 'jínternecs de las cosas'.
  4. lujar
    lujar Sir Scale 910
    11 Oct 2012
    En la Costa Tropical
    A vosotros os salen estos archivos cuando conectais el fenix3 al pc?? El de ERR_LOG.BAK os sale?? Lo mismo el problema es por eso no??
  5. Rafuky
    Rafuky Miembro activo
    12 Jun 2011
    Las Rozas
    Hola buenas tardes a todo. Después de varios meses leyendoos pongo a la venta mi Fenix3 Zafiro, con banda, correa y todos sus accesorios. PRECIO 400E. Mas Info por privado
    Disculpad el off THE récord
  6. lujar
    lujar Sir Scale 910
    11 Oct 2012
    Aquí tampoco es el sitio correcto, ya te lo han dicho en el foro de atletismo, ponlo en su sección correspondiente de compraventa
  7. Rafuky
    12 Jun 2011
    Las Rozas
    Lujar: Tantos se han anunciado hijo, que por uno mas ... pero vamos no te preocupes que ya esta hecho ...
  8. Binomio Karmesi
    24 Dic 2008
    Lujar, esta tarde conecto el aparatico a la partición de windows y te comento.
    En cuanto al proceso de actualizar/bajar firmware, trataré de traducir el texto para que le pueda echar un ojo el personal más cómodamente.
  9. lujar
    lujar Sir Scale 910
    11 Oct 2012
  10. junaca74
    junaca74 Miembro activo
    10 Mar 2015
    Sera de agradecer binomio
    Graciasss
  11. lujar
    lujar Sir Scale 910
    11 Oct 2012
    Bueno, pues hoy he hecho una salida en bici para comparar el fenix 3 con el Edge810, la verdad que los datos son bastantes similares como podeis ver en estas capturas de pantalla, deciros q la banda de pulso solo la llevaba emparejada con el 810, qué opinais??
    [​IMG][​IMG]
  12. Binomio Karmesi
    24 Dic 2008
    La banda de pulso emparejada con el 810??? y salen solo 400 Cal? y el F3 marca casi 2000 Cal?
  13. lujar
    lujar Sir Scale 910
    11 Oct 2012
    Así es!! Las calorias las calculan estos cacharros a razón de pulsaciones y zonas de frecuencia cardiaca por lo q el fenix3 al no llevarla emparejada un disparate
  14. Pperiago
    Pperiago Miembro
    16 Mar 2015
    No solo es eso, tambien tiene en cuenta tus caracteristicas. Desconozco tu peso, pulsaciones y el recorrido que hiciste etc..., pero 413 calorias para 53 km y más de dos horas de bici, me parece poquísimo. Yo ayer hice una ruta mixta MTB/Carretera de 42 km... eso si con casi 900 metros de ganancia de altura, y el Fenix con la banda me dió 1.325 calorias y Strava 1.524. Alguna vez fui si banda y noté que el gasto marcado era mayor, pero no una exageración y muy parecido a lo marcado por Strava.
    Salu2
  15. lujar
    lujar Sir Scale 910
    11 Oct 2012
    Con una frec cardiaca media de 94ppm no lo veo muy mal..
  16. germanete
    germanete Miembro Reconocido
    27 Ene 2012
    A mi lo que mas me ha chocado es la diferencia en la altura ganada, alrededor del 20% de diferencia es mucha diferencia.
  17. Pperiago
    Pperiago Miembro
    16 Mar 2015
    Estás fuerte!! ;)
  18. lujar
    lujar Sir Scale 910
    11 Oct 2012
    Ten en cuenta q el edge tenia calibrada la altura correcta en el punto de inicio y el fenix no
  19. lujar
    lujar Sir Scale 910
    11 Oct 2012
    Se hace lo q se puede, ahí lo llevas para q veas q no es farol [​IMG]
  20. Binomio Karmesi
    24 Dic 2008
    Me sale lo mismo
