Post Del Dopaje
Tema en 'Profesionales / Élite / Sub-23' iniciado por serpal, 30 Jul 2007.
  1. Felix87
    Felix87 Miembro activo
    28 Ago 2014
    Nos tenemos que creer que la UCI no sanciona a alguien que da el doble de una sustancia prohibida y que una muestra de hace 8 años tiene "anomalías", se están cargando el ciclismo, solo se remueve la ****** en este deporte. Que pasaría si reanalizan muestras del fútbol? Igual ganaría la champions el Logroñes por descarte....
  2. bonus
    bonus er petao
    26 Abr 2005
    en el paraiso de las piedras
    The Union Cycliste Internationale (UCI) announces that the UCI Anti-Doping Tribunal has rendered its decision in the case involving Juan José Cobo Acebo.
    The Anti-Doping Tribunal found the retired rider guilty of an anti-doping rule violation (Use of a prohibited substance) based on abnormalities from 2009 and 2011 detected in his Biological Passport* and imposed a three-year period of ineligibility on the rider. In accordance with the Procedural Rules of the Anti-Doping Tribunal, the decision will be published on the UCI website in due course.
    The decision may be appealed before the Court of Arbitration for Sport pursuant to Article 30.2 of the UCI Anti-Doping Tribunal Procedural Rules and Article 74 of the UCI Constitution within one month as of today.
    At this stage of the procedure, the UCI will no make any further comments.
    (*) An Athlete Biological Passport (ABP) is an individual, electronic record for each rider, in which the results of all doping tests collected in the framework of this programme over a period of time are collated. The management of the ABP programme is carried out by the Cycling Anti-Doping Foundation, the independent body mandated by the UCI to carry out the anti-doping testing programme in cycling.
    Ahí dejo el comunicado de la UCI...
  3. ktmmtb
    ktmmtb Miembro Reconocido
    17 Oct 2015
    La UCI va a proponer dejar desiertos los podios,y en 10 años,si está todo OK,entregar el premio
  4. Ritxis
    Ritxis Miembro Reconocido
    2 Jun 2007
    Donosti
    :D:D:D:D
  5. suprememtb
    24 Sep 2006
    Tienes alguna prueba que demuestre lo contrario?
  6. Arenberg
    Arenberg Miembro Reconocido
    16 May 2014
    Menudo sorpresón lo de Cobo, ¿no?
    :D:D:D
  7. BorjaHinojedo
    BorjaHinojedo Miembro Reconocido
    14 Oct 2010
    Cantabria
    Mira....me dices a mi que le quitas la vuelta a Cobo? Ok, si es culpable estamos de acuerdo, hay que sancionar lo ilegal!
    Pero....para dársela a Froome?? Me parto!! debe ser que iba limpio el tío! igual que hace 2 años en la vuelta, dando le doble de lo permitido, y son datos, no opiniones (los médicos aseguran que es imposible llegar a esa cantidad de Salbutamol con inhaladores)
    Si ya hace 2 años iba enchufado, como iría hace 8!! pues igual que el otro!
    Analiza a los 10 primeros por lo menos ****....
    • No estoy de acuerdo No estoy de acuerdo x 5
  8. Capitan Ginyu
    Capitan Ginyu Miembro Reconocido
    14 Ene 2007
    Oleiros
  9. Capitan Ginyu
    14 Ene 2007
    Oleiros
    Evidentemente no...
  10. carter
    carter el precio del poder
    13 Ago 2007
    sabadell, vallirana
    Einn? También salió lo de lance más tarde y todos lo sabíamos..como con Cobo.
    Si haces trampa, se tiene que saber, tarde o temprano
  11. carter
    13 Ago 2007
    sabadell, vallirana
    Si
    Con snickers no se puede ganar jjj
  12. carter
    13 Ago 2007
    sabadell, vallirana
    1 la sustancia no era prohibida
    2 lo del fútbol no tiene que tapar lo del ciclismo
  13. Abdujaparov
    Abdujaparov Miembro Reconocido
    11 Dic 2016
    España
    La tienes tú contra Cobo? o nos creemos a la UCI mafia a pies juntillas?
    GRANDE MUY GRANDE EL BISONTE DE LA PESA.
  14. ktmmtb
    17 Oct 2015
    Si el metodo es fiable,y siguen tirando de ''Congelados'', caerán unos cuantos mas.
    Dependiendo de si quieren seguir tirando de la manta,y a quien quieran pillar.
    Tampoco se que criterio siguen,o si solo investigan a corredores que en su dia levantaban sospechas.
    Continuará....
    No se van a cargar al ciclismo,porque los Aficionad@s tienen mucho mas empuje que la Uci,y todas las agencias llenas de Siglas y Mafiosos juntos.
    Tampoco veo a la agencia que corresponda,tirando de Orina del Mundial de futbol de hace X años,y quitando titulos.
    Primero porque no se les persigue tanto,y segundo porque les faltan huevos.
    Última edición: 13 Jun 2019
  15. Cuprix
    Cuprix Miembro Reconocido
    3 Ago 2011
    Ibiza
    No sé qué manía tiene la gente con ver fantasmas. He conocido gente relacionada con el atidoping y son profesionales honrados que intenta pillar a todo el que se salga las normas.
    Si tenemos que ponerlo todo en duda mal vamos. Hay gente a la que le apasiona su trabajo y no se deja llevar por forofismos ni memeces varias, simplemente si no pillan a más es porque no pueden o porque tienen menos recursos que un equipo de Tercera División.
    Tiene que caer Froome? Pues si ha hecho trampas que caiga ahora o en 10 años. Y si no, pues es inocente hasta que se demuestre lo contrario. Y el caso Salbutamol lo ha ganado, guste más o menos el final.
  16. kakotas
    kakotas Miembro Reconocido
    5 Dic 2006
    anero-portugalete
    gran dia para el ciclismo se hizo justicia ami me daba verguenza ajena aquel año
  17. Fermineitor
    Fermineitor Miembro activo
    19 Ene 2013
    ¿Y de qué sirve quitarle los títulos a un tío retirado?
    Es como lo de pedir perdón por la conquista de América...
  18. lolo
    lolo Miembro Reconocido
    11 Ene 2005
    Muros (Asturies) y Usansolo(Bizkaia)
    cierto, es más creo yo un tema burocratico o administrativo... y que iban a hacer, le han pillado ahora, ¿meten el resultado en un cajón y se olvidan?...
  19. canario74
    canario74 Miembro Reconocido
    19 Jul 2014
    Sestao
    Para darselos al ganador que no dio positivo por ejemplo o para quitarle aparecer en los anales de la historia como legitimo ganador. Que pena que no existiera todo esto hace 20 años, cuanto habrian cambiado los podiums, algunos idolos ivan a quedar retratados.
    Enviado desde mi Redmi 4 mediante Tapatalk
  20. fjse1966
    fjse1966 Miembro del Globeros Tim
    22 Jul 2005
    Lat. 40° 35' 50'' N Long. 3° 29' 46'' O
    Viendo el devenir de los acontecimientos si estos analisis se hubieran hecho hace 20 años, teniamos la clasificación vacia por descalificación del 99% de los corredores de la época.
